Taylorway 245 brush/rotary cutter
coobie
03-16-2008 15:41:42
I am looking at a new taylorway 245 brush/rotary cutter 5ft.From what I know it has a 50hp gear box and they are made by Taylor pittsburgh company located in Athens TN.Has anyone used one of these cutters,if so how do you like it?Thanks.coobie :)
redbovine
03-17-2008 18:22:59
 Re: Taylorway 245 brush/rotary cutter in reply to coobie, 03-16-2008 15:41:42
I have purchased several TP products over the years and what I liked about them was the thickness of the deck plating. If you puck up a rock it won't dent it because it is a heavy piece of equipment. A 50 hp gear box is sufficient on a 5 ft cutter but I like to compare gear box, deck plat thickness and price before buying.
coobie
03-18-2008 00:14:31
 Re: Taylorway 245 brush/rotary cutter in reply to redbovine, 03-17-2008 18:22:59
redbovine said: (quoted from post at 18:22:59 03/17/08) I have purchased several TP products over the years and what I liked about them was the thickness of the deck plating. If you puck up a rock it won't dent it because it is a heavy piece of equipment. A 50 hp gear box is sufficient on a 5 ft cutter but I like to compare gear box, deck plat thickness and price before buying.
Thanks for the info.coobie :)
