Tractor Talk Discussion Forum
thats the last one
Lanse
03-16-2008 18:57:22
third party image
I got my front rim today, met up with HillbillyOH a few miles from here and played with his tractors for a little while. I got the rim home and found it is a 5 bolt rim and i have a 6. First job was removing the old rim, then i took my new grinder and removed the bolt heads and pounded the rim off the wheel thing (that attatches to the spindle) but it diddnt want to move so i had to drill through the bolts to the wheel, through the rim, then seperated the 2 with a hammer, then cleaned it up. I'll have to pick up a few bolts for it and drill some new holes in the wheel, but i think it'll work. The new rim apperes to have a spare tire from a car on it, but its better then the tire on the old rim and will do until i get a pair of 3 ribs for it.
hillbillyOH
03-17-2008 04:13:50
 Re: thats the last one in reply to Lanse, 03-16-2008 18:57:22
I feel bad about selling you the wrong rim, Lanse. I had no idea the B/C rims were different. Let me know if you want to exchange/refund.
You did a good job driving the M and the C! Next time we'll put you to work raking hay or spreading manure. :)
Lanse
03-17-2008 04:23:43
 Re: thats the last one in reply to hillbillyOH, 03-17-2008 04:13:50
Thats ok, honest mistake. I'll try what im doing, or mabey i can find the right little wheel thing. That rim is in great shape, and i'd like to use if if at all possible....and thanks :-)
135 Fan
03-16-2008 19:52:18
You want to be bang on if drilling new holes in the rim. I don't know if the old rims have a raised lip around the hole to help keep the lug nuts tight. The proper rim would be better. Dave
Lanse
03-17-2008 03:15:36
 Re: thats the last one in reply to 135 Fan, 03-16-2008 19:52:18
no, its the little disk that the rim bolts to, where the little bolts were, theres a lip about 1/8 inch
old
03-16-2008 19:26:27
Lance I probably have a couple of the correct rims laying around for your tractor. But I do have 2 Cs here for parts
