Tractor Talk Discussion Forum
IH 1086 remote valve rebuild kit
bemhoff
03-16-2008 19:48:44
Does anyone know who makes or sells rebuild kits for the IH (1086)remote control valves? These are a simple valve and should be easily rebuilt for way less than purchasing a rebuilt or new vlave.
Thanks
IaGary
03-17-2008 04:50:26
 Re: IH 1086 remote valve rebuild kit in reply to bemhoff, 03-16-2008 19:48:44
What is wore on yours?
I have put new o-rings in mine and new pins and linkage irons on the levers. Nothing else has ever wore out.
Gary
bemhoff
03-17-2008 07:09:40
 Re: IH 1086 remote valve rebuild kit in reply to IaGary, 03-17-2008 04:50:26
The only thing that is wore is the end of the spool piece where the pin goes through it. I can probably fix this, but I figured since I would have the vlave off I might as well rebuild it. I have some leaks and the detents don't seem to work properly. thanks
IaGary
03-17-2008 17:11:25
 Re: IH 1086 remote valve rebuild kit in reply to bemhoff, 03-17-2008 07:09:40
I drill them out one size bigger and there is an oversize rebuild kit for it.
Your detents will come back when you fix the slop in the lever.
You can spin the plunger and drill it right on the tractor so no need to remove.
Gary
Bob
03-16-2008 20:30:13
Have you tried CNH?
bemhoff
03-17-2008 07:05:52
 Re: IH 1086 remote valve rebuild kit in reply to Bob, 03-16-2008 20:30:13
Yep, my local dealer told me that the parts are only avaliable seperatly and not all are avaliable. Thanks
