Tractor Talk Discussion Forum
Case DC won't start
Dalton S.
03-21-2008 16:20:58
I have rewired my DC case. When I tried to start it, it will just sorta backfire, and it will get flooded. Exaust will come out of the carbuerator and around the manifold. I have cleaned the carberator out and dried out the spark plugs, but it will still do the same thing. It ran and started fine before I rewired it, so I dont know if its in the electrical or something else. Please help!!
El Toro
03-22-2008 04:00:16
 Re: Case DC won't start in reply to Dalton S., 03-21-2008 16:20:58
If you ran battery voltage to a mag you probably cooked the points, condenser or coil on the mag.
Take a look at the cap for small cracks. Hal
Walt davies
03-21-2008 17:50:38
Its either out of time or you have spark plug wire crossed none of the other wires can cause this unless you hooked the Mag wire up to a hot wire its supposed to go from ground to switch to Mag. You stop the tractor by grounding the mag. Walt
Larry Harpster
03-21-2008 16:26:42
If rewiring included sparkplug wires I'd check the firing order and make sure the plug wires are right.
Dalton S.
03-21-2008 16:29:43
 Re: Case DC won't start in reply to Larry Harpster, 03-21-2008 16:26:42
The reiwiring didnt include the spark plugs. I replaced the spark plugs and wires before I replace the other wiring, and it started and ran fine.
Lanse
03-21-2008 16:31:06
 Re: Case DC won't start in reply to Dalton S., 03-21-2008 16:29:43
lets narrow it down, what other ignition system components did you work on??
Dalton S.
03-21-2008 16:54:03
 Re: Case DC won't start in reply to Lanse, 03-21-2008 16:31:06
The olny thing I worked on was the wires for the lights, generator, on/off to magneto.
garytomaszewski
03-21-2008 18:27:04
 Re: Case DC won't start in reply to Dalton S., 03-21-2008 16:54:03
HMM, Ran fine until you fixed it. Take the wires, NOT THE PLUG WIRES off the mag, if you haven't cooked it by giving it power, you should run. You can then shut it off by closing the fuel valve.
Mathias NY
03-21-2008 18:40:09
 Re: Case DC won't start in reply to garytomaszewski, 03-21-2008 18:27:04
"If you haven't cooked it". Last spring I spot-welded the points on my DC's original magneto by connecting the ground wire to 6v+. Whoops.
I also found that the 'professional' rebuilder had reinstalled the rotor 10 degrees out of time. It took a little bit to trouble shoot that one.
Good luck.
Lanse
03-21-2008 17:30:14
the on/off sounds probable, since a genorator shouldnt affect how a mag tractor runs. Mabey theres a bad switch or a loose connection in there???
