Tractor Talk Discussion Forum
424 international oil pressure
jfloyd
03-22-2008 15:12:15
Does anyone know how much pressure it takes to hold off the factory idiot light? Is this port the full pressure of the pump? I removed the sending unitand put a gauge on this port. I see 22# cold and next to none idling hot. I see another plug on the filter housing but haven"t tried it. What does it take to keep one of these from knocking apart?
BW in MO
03-22-2008 18:18:42
 Re: 424 international oil pressure in reply to jfloyd, 03-22-2008 15:12:15
First check the plate on the bottom of oil pump I have had them to blow the gasket & warp the plate. I replaced plate & gasket had no trouble after that.
IH2444
03-22-2008 15:56:31
I think the plug on the oil filter housing is just to drain the upside down filter with less mess.
Is that the C142 engine ?
RAB
03-22-2008 15:34:49
They say 5 psi is enough to keep a plain bearing apart. You may not have that at all your bearings. The factory idiot pressure warning switch will possibly have a rating on it, or can be cross referenced, but usually they only indicate a few psi probably in the range of 4 -8 psi at a guess. If it is on you are in trouble if your pressure readings are correct. Could be bypass vave (seat or spring), pump, loose bearings, oil quality, an internal leak, wrong and/or blocked filter, blocked oil pick-up, leak on pick-up, low oil level. You definitely need to investigate before it knocks itself apart.
RAB
jfloyd
03-22-2008 17:21:33
 Re: 424 international oil pressure in reply to RAB, 03-22-2008 15:34:49
c-146
No knocking.
The light hasn't worked in decades. Clean filter, clean pickup. It's on 10W40. New Rod bearings, 2 new mains (not rear) old cam bearings. I was just expecting a little more but have no idea what it was before. Maybe a pump would be good insurance.
