Tractor Talk Discussion Forum
International 986 TA
IHPRIDE
03-23-2008 21:13:26
I bought a IH 986 about a year and a half ago and the TA handle in the cab is starting to stick and pulls hard? Wanting to know if there is a cable or something that needs lubrication!! Thanks.
LBSMJS
03-24-2008 19:00:39
 Re: International 986 TA in reply to IHPRIDE, 03-23-2008 21:13:26
You can replace the detent link if the roller is worn.The new one is a needle brg inside the roller where the old style link is a roller on a shaft & the roller will wear into the shaft and move hard enough to bend the lever.
Allan In NE
03-24-2008 05:24:13
Get 'er lubed up good on both ends like Lee says.
You really don't want the pleasure of having to replace that cable, believe me. It's kind of a pain in the butt.
Allan
Lee in Iowa
03-23-2008 22:30:54
My 1486 gets sticky once in a while and I just have to put the straw on a can of penetrating oil and aim it through the slot at the bottom of the handle and spray while work the handle back and forth. Lee
