Tractor Talk Discussion Forum
Stabalizer Bars
fergienewbee
03-26-2008 05:17:56
This is a dumb question, but when do I need to install stabalizer bars on my 3PH? I plan to get a "carry all" for moving firewood, and other stuff. I also plan to do some disking. Do I need stabalizer bars for either one? Thanks.
Larry
fergienewbee
03-26-2008 10:58:19
 Re: Stabalizer Bars in reply to fergienewbee, 03-26-2008 05:17:56
Thanks for the information. Probably saved a lot of repairs.
Larry
MF Poor
03-26-2008 08:30:32
By your screenname, I'm assuming we're talking about a Ferguson? If so, stabilizer bars are almost a nessecity on most implements. Those tractors don't have sway blocks like so many other brands use. 3-point lower links are free to swing quite a ways in each direction without them. 3-point mounted plows, disc, or planters being exceptions. That would be like a ship with a locked rudder. You need some movement with implements like them. Any other type of implement, such as a mower, carry-all, rear blade, bale spear, ect, and it's stabilizer bars all the way. Saves broken draft arms among other things.
Dan in Houston
03-26-2008 06:38:28
You don't "need" them, but depending on your tractor, you may get a lot of side to side sway of the implement on the hitch without them. My JD has chains with turn-buckles on each side, so I don't need them. However, a lot of tractors have so much side to side sway in the 3 pt. that it is a pain without them.
Allan In NE
03-26-2008 05:31:06
I cinch 'em up on everything.
Allan
