Tractor Talk Discussion Forum
Plow tail wheel?
Chances R
03-27-2008 17:37:14
So why does a tail wheel have to be leaned over at a pretty good angle and not straight up and down? Thanks
Chances R
03-28-2008 06:42:42
 Re: Plow tail wheel? in reply to Chances R, 03-27-2008 17:37:14
Thanks for all the replies even yours Big G :)
mjbrown
03-28-2008 05:19:23
The forces on the plow are down (weight) and toward the furrow wall. The tail wheel is canted to deal with the combination of those forces. If it were verticle the wheel bearings would have a lot of side load.
Big G
03-27-2008 19:24:35
OUCH!!!!! Ok I'm done..... Your memory serves you well..
Big G
03-27-2008 18:20:28
It is about steering the plow in the furrow and out at the fields end for turning around. Some time and place maybe you can study it more when your behind me and my G John Deere. I can't recall a time when you've taken the lead pull. But at least your still running. Sorry just a little friendly jab. lol!
Chances R
03-27-2008 18:51:39
 Re: Plow tail wheel? in reply to Big G, 03-27-2008 18:20:28
Well now if I remember right the last time I went plowing with you I was plowing circles around you with that L-GM Case. And the time before the old C Case was the only tactor out in the field plowing cause all the rest of you guys were on the side lines broke down. And the time before that at Kron farms there was a G that you were on that looked like a steam engine after that head gasket blew. Have a good night. lol
LenND
03-27-2008 18:11:42
They are also tapered so they will bite into the side of the furrow to keep it from climbing out.
davediehl@hotmail.com
03-27-2008 17:43:34
Once you drop it in the ground, it levels. Its a steering thing.
