Re: Rochester 4 barrel carb questions
kipn
03-28-2008 12:38:25
If I remember right, the lower butterfly shaft will wear the throttle body and will bind, not close all the way, but only when running, causing a higher idle. Something to do with the vacumn. Always remembered customers not understanding the $ to fix it.
bradk
03-28-2008 13:18:11
 Re: Rochester 4 barrel carb questions in reply to kipn, 03-28-2008 12:38:25
Yep,I ran into the worn primary throttle shafts on lots of Roch Q-jets.So many that I bought a kit to ream and install bushings.
Makes big differnce in idle quality.
Brian Jasper co. Ia
03-29-2008 11:54:51
 Re: Rochester 4 barrel carb questions in reply to bradk, 03-28-2008 13:18:11
The other problem is many guys overtighten the mounting bolts. This warps the top cover and will cause worse idle problems than worn throttle shaft bushings.
