Tractor Talk Discussion Forum
Torching Spot Weld?
Tim in New York
03-29-2008 13:55:57
I'm rebuilding an old spreader that was converted to a firewood trailer 25 years ago. There are metal straps spot welded across the uprights that I need to remove. Don't have a welder or a real torch, just a bottle torch. Can I get the weld hot enough to break it and remove the straps?
Thanks,
Tim
bradk
03-29-2008 15:40:20
 Re: Torching Spot Weld? in reply to Tim in New York, 03-29-2008 13:55:57
I have special spot weld drill bits for just that type of work.Body shops use them alot.Bent a snout on the combine and had lots of spot weld to drill,makes for fast removal.
Tim in New York
03-29-2008 15:21:49
Thanks everyone for the quick reponses. To town tomorrow for a grinder and air filter for the tractor.
Tim
ispud
03-29-2008 15:05:16
Get a cheap HF 4.5 grinder [about 10 to 15 bucks] but get some of their cut off wheels, just got a flyer their on sale 10 for 2.99.They will go through spot weld like a hot knife through butter, Ive used them for years.
Janicholson
03-29-2008 14:45:10
If they are "welded in spots" on each upright, a $30 4" grinder from Northern Tool etc. will do it. If they are spot welds from a spot welder, a high quality drill bit will take them out. JimN
Two Dogs
03-29-2008 14:13:16
Can you get to them with a grinder?
Tim in New York
03-29-2008 14:15:13
 Re: Torching Spot Weld? in reply to Two Dogs, 03-29-2008 14:13:16
Never thought of that - I should be able to. But of course I don't have a grinder....but it will cost less to buy one than have the local welder stop by.
Thanks!
Tim
Two Dogs
03-29-2008 14:25:02
 Re: Torching Spot Weld? in reply to Tim in New York, 03-29-2008 14:15:13
You"re welcome. You will find a lot of other uses for the grinder. One use I come across once in a while is removing extra skin and cloth from various body areas.:)
olddog
03-29-2008 16:41:33
 Re: Torching Spot Weld? in reply to Two Dogs, 03-29-2008 14:25:02
Ya forgot ta mention another good use fer 'em....
They will sanitize a big spot in yer shirt, if ya point the sparks just rite...
JRT
03-29-2008 20:44:58
 Re: Torching Spot Weld? in reply to olddog, 03-29-2008 16:41:33
Yea, and another thing they have been known to do. Catch a man's shirt on fire. I have ruined a couple of good shirts that way.
