Tractor Talk Discussion Forum
Help with Kohler toilet problem
loveshisallis
03-31-2008 13:15:40
I have one of those "modern" 1.? gallon one piece toilets and it has a smell problem. I wash out the tank and scrubbed the bowl and the (musty)smell goes away for a week or two. Then, the water tuens grey and the smell returns. Yes, the surrounding area is clean. Scrubbed it on my hand and knees with bleach.
I know that the water lines are clean and I get very clear water in all of the other fixtures.
So, I would sure appreciate any advice as to what it causing the stink.
thanks
Billy NY
03-31-2008 13:56:34
 Re: Help with Kohler toilet problem in reply to loveshisallis, 03-31-2008 13:15:40
This may be way off, but does the water disperse evenly under the rim, cleaning off the waste after each use. Boy I'll tell you, some people don't realize how much spray gets on the surrounding area of a toilet by this half of the gender, it soaks into tile joints and also creates an odor that can be hard to get rid of. Corrodes radiators, metal partitions, in the last few years of doing some repair work to keep busy, I've seen a lot of bathrooms that are cramped and hard to clean.
I've had a similar problem, no change in water though, new toilet on concrete floor in garage, concrete has capillaries and it can absorb, took a good cleaning, no slobs in the house either, this one gets cleaned 1x week and always wiped down with a cleaning spray daily, as does the floor 1x week and for a while this urine like odor would not go away, warmer weather never figured it out, just cleaned, disinfected, solvents on the concrete, finally gone. Seemed like it came out of nowhere, thought the stack vent was clogged or there was another source, can't stand a filthy bathroom that is for sure.
One of my customers tenant space had that problem, had to pull the toilet and take the tile up, was a police substation, lot of traffic, sometimes these odors come from years of saturation like at this place, no amount of cleaning would have solved this one.
Have never heard of the water turning like that, maybe you can get it tested.
GeneMO
03-31-2008 13:21:01
It sounds like there is some place, hidden, that is harboring bacteria or something. Maybe try adding Clorox to the tank with every flush for a day or so. Might kill it off. I know the well drill people have Clorox tablets, but not sure if they are a slow release type.
Gene
RayP(MI)
03-31-2008 14:19:41
 Re: Help with Kohler toilet problem in reply to GeneMO, 03-31-2008 13:21:01
They make a Clorox product about the size of a hockey puck. Put it in the tank, slow release - lasts a week or two here. Works for us - you can smell the chlorine in the bathroom. Not over powering, but seems to work well keeping stains in bowl down, and smelling fresh.
loveshisallis
03-31-2008 13:27:55
Thanks Gene...I will give that a try.
why didn't I think of that?????
