Tractor Talk Discussion Forum
Jack hammer
BuddyBear
04-03-2008 20:47:25
I bought a jack hammer that had been converted to hydraulic power. The engine and pump work fine but the jack hammer doesn't have much of a snap to it. The seller said there is a nitrogen chamber on it and it could need charging. I found the chamber and it has a valve like a tire valve. I pushed on the stem and nothing came out so it must be empty. How much pressure should be in there? The guy said its a 90 lb. hammer but I don't think it weighs quite that much, but its salty enough. Any info is appreaciated as I obviously don't know much about it.
Thanks in advance
Leland
04-03-2008 22:04:54
 Re: Jack hammer in reply to BuddyBear, 04-03-2008 20:47:25
A place that recharges fire extinguishers can test it for you and recharge .
135 Fan
04-03-2008 21:31:23
Find out from the manufacturer if it doesn't say. I think some are up to 300 PSI. Dave
Walt davies
04-03-2008 21:14:21
You need to take the hammer apart and see if the bladder is OK no sense in wasting nitrogen and these thing do get holes in them. the place where you fill it should have the correct PSI.
Walt
