Tractor Talk Discussion Forum
Small engine electrical HELP!!!
Need To Know
04-06-2008 05:15:18
Wasnt sure where to post this question,so here it is.I bought(off Ebay with no owners manual) a brand new 11hp tecumseh electric start horizontal shaft motor.I dont need the electric start but want to run a small headlight off the motor.The motor has a whip coming out with a red,green,yellow and black wire(the black wire is grounded to the motor) going into a plug.How to I tell which wire with the motor running would have juice,and what would the other two wires be for? I'm not that bright and dont want to damage anything.Thanks
MarkB_MI
04-06-2008 06:59:27
 Re: Small engine electrical HELP!!! in reply to Need To Know, 04-06-2008 05:15:18
The alternator outputs of most small engines are unregulated. You're likely to burn up your light bulb if you hook it directly to the alternator without a battery in the system.
Bob
04-06-2008 10:03:32
 Re: Small engine electrical HELP!!! in reply to MarkB_MI, 04-06-2008 06:59:27
It's done all the time with tecumseh engines on walk-behind snowthrowers, NO big deal.
guido
04-06-2008 06:03:04
Hello Need To Know.
You are better off using power from the battery. Use a switch to turn it off , and don't forget to fuse the circuit.The fuse size should be 50% more than what the circuit amps.
10 amp draw 15 amp fuse.
If you want to you the ignition key email me and I'll send you a diagram for a relay. Guido.
BWF
04-06-2008 05:50:00
This may not be what you want to do but I would just run a hot wire to the battery and put a switch on it.
Bob
04-06-2008 05:37:54
You didn't give us much to go on as to what specific engine you have! Anyhow, here's how Tecumseh has TRADITIONALLY done this: (DON'T blame me if you "let all the smoke out" of the poor thing's electrical system!)
red..... Rectified DC power for battery charging
green....Ground this wire to "kill" the engine
yellow...AC power to run a headlamp
black....Ground
UncleTom
04-06-2008 08:02:39
 Re: Small engine electrical HELP!!! in reply to Bob, 04-06-2008 05:37:54
I think Bob has it right.
