Tractor Talk Discussion Forum
farmall BN starter
jim jackson
04-06-2008 14:57:02
i have a 1941 farmall BN,..anyone know what different model tractor starters will fit,..
gene bender
04-06-2008 15:45:58
 Re: farmall BN starter in reply to jim jackson, 04-06-2008 14:57:02
If you want the original with the kick rod that pushes the starter sw the only one the same is from an A or B. The C.SC.SA and newer ones have a pull rod thus the button for the sw is on the rear. The H uses a threaded post and needs a heavy sw or a solenoid to operate.
old
04-06-2008 15:10:08
Just to add one more a starter off an H will also fit. I know because I have a starter off a B on and H. The starter from an H is a heavier duty one then what would be on a B/BN but will still work and probably last longer
Red Dave
04-06-2008 14:59:07
A, B, BN, AV, Super A, Super AV, C, Super C. Maybe some others too.
