Tractor Talk Discussion Forum
Running gear bearing revisited.
Bernsy MN.
04-07-2008 07:36:40
A few weeks back I posted a picture of a roller bearing that I need to replace, I do have the demensions. Someone posted that they may have some, I can't find original post. My IH dealer cant get new ones either, went to several bearing shops to no avail. Picture is in parts & peices under old running gear. Thanks for any assistance.
RayP(MI)
04-07-2008 14:27:32
 Re: Running gear bearing revisited. in reply to Bernsy MN., 04-07-2008 07:36:40
If you have the dimmensions, a good bearing shop should be able to find something that fits. I've had good luck with DETROIT BALL BEARING - google them. If you have a good counter man at NAPA, check with them. They have a large assortment, and sources.
Heat Houser
04-07-2008 10:35:48
Yup, we used to have an IH running gear that used this bearing. Ours was newer so it was not a spoked wheel. Did you try some old time salvage yards? This same bearing was also used on the front of the horse drawn manure spreader of that vintage.
I don't know if the old running gear is still at the home place or not.
Iagary
04-07-2008 08:10:19
I would use to 2 ball bearings with a spacer between them to make up the width needed.
Measure your shaft size and your hub size and get a bearing that will fit by those measurments.
Gary
