Tractor Talk Discussion Forum
IH Hydro tractors
lilnoki
04-08-2008 21:19:40
I have seen some IH tractors with "Hydro" on them. What is Hydro?
paul
04-08-2008 23:08:42
 Re: IH Hydro tractors in reply to lilnoki, 04-08-2008 21:19:40
Great for loader work, snow blowing, baling, other work where infinite speed is a plus.
Suck more fuel - hydro is not near as efficient as gears so forget about plowing or heavy tillage; and more $$$ to fix when they break. Folks like them, so ya kinda have to be suspicious when you find one for sale, how wrecked is it..... .
--->Paul
Bob
04-08-2008 21:45:34
They used a combination of a variable piston pump AND a variable piston MOTOR ahead of the gear transmission to give a wide range of speed control in the forward and reverse directions with the use of a single speed control lever, much like a "hydro" garden tractor.
Joe(TX)
04-09-2008 09:14:46
 Re: IH Hydro tractors in reply to Bob, 04-08-2008 21:45:34
I beleive only the pump is variable. The motor is fixed.
Bob
04-09-2008 19:35:23
 Re: IH Hydro tractors in reply to Joe(TX), 04-09-2008 09:14:46
You are WRONG, hydraulic oil breath!
The motor AND the pump are variable displacement on the TRACTORS.
You can see the two gimbaled swashplates in this drawing, which pivot on tapered roller bearings, and there is a servo for BOTH the pump swashplate AND the motor swashplate.
Third Party Image
Motor servo:
Third Party Image
Pump servo:
Third Party Image
Dean Barker
04-08-2008 21:31:50
They had a fully hydrostatic transmission with two or three ranges.
lilnoki
04-09-2008 19:50:01
 Re: IH Hydro tractors in reply to Dean Barker, 04-08-2008 21:31:50
Thanks for all the info everyone. I totally understand hydrostatics, I just did not know they had them on the IH tractors.
