Tractor Talk Discussion Forum
Loud Clutch
MF294-4
04-10-2008 19:25:52
My MF294-4 that I have had for several years, has always had a loud noise in the clutch when you slip it taking off. You can't feel it in the pedal but it makes a loud vibrating until you let up on the pedal more. Clutch doesn't slip and otherwise works fine. Tractor has 5600hrs and I can't find any maintaince records. Any suggestions.
Larry59
04-11-2008 07:10:15
 Re: Loud Clutch in reply to MF294-4, 04-10-2008 19:25:52
I agree with a throw out bearing and the clutch still works fine. Better get one soon. But when you do. Take your clutch to a rebuilder and maybe have the fly wheel turned if needed. My tractor is a case. Got all done as I mention above from a rebulder for a total cost of parts at $215.00. A friend broke it down and fixed it for me.
Edpap
04-10-2008 20:44:50
your tractor has a two stage clutch if you are getting a vibration in the pedal when you are slipping the clutch I would think the clutch disk is comming apart.if it stops half way up ( the PTO)it would not be the throw out bearing.
I can get you a clutch if you need one they are alittle pricey some where around $700.
Thanks Ed
Sid
04-10-2008 20:16:21
Not familiar with that tractor. Sounds like throw out bearing to me.
Old Roy agiin
04-10-2008 20:16:30
A chattering noise ? does it engage smooth? If not, could be your pressure plate needs resurfaced.Or it could be oil or grease on clutch surfaces.
