Tractor Talk Discussion Forum
$45 for one u-joint??
Truth seeker
04-10-2008 20:20:10
Hi!
Our 5 foot long rototiller pto trashed one of it's u-joint's, we used a different pto shaft last season and had set this one aside. Now I'm wanting to get it fixed, but the local parts store said that it wasn't a common u-joint, and quoted a price of $45!
This seems a little out of line to me, But I've only bought ones for our automobiles before. What do you think?
Bob
04-11-2008 11:42:31
 Measure it... in reply to Truth seeker, 04-10-2008 20:20:10
In the time it took you to just whine about it, you could have posted a photo and some dimensions.
I have several u-joint catalogs, as I'm sure several others on here do as well.
With dimensions, there's a good possibility someone can cross-reference it to a generic part, for a lot less $$$.
RodInNS
04-11-2008 06:04:26
 Re: $45 for one u-joint?? in reply to Truth seeker, 04-10-2008 20:20:10
It's a bunch of money for sure.... but it could be worse. Try a grand for a constant velocity joint or over a hundred bucks for a simple cross on some of the metric shafts. If it's just a small 40-50 hp shaft (metric) then I think it's a bit much, but probably not too far out of line. If it's a standard shaft then most I've bought were in the 15-20 buck range.
Rod
Gary in TX
04-11-2008 05:30:01
I'll trade ya, one on my New Holland 1441 MoCo costs I believe I remember right $150.00 or better(more like 175.00 I think).
djw
04-11-2008 05:29:02
I have a long rototiller I recently purchased , I noticed it does not have a slip clutch or shear pin, is that the way yours is set up? thanks Dave
hay
04-11-2008 03:20:18
most NAPA auto parts stores ( at least here in se texas) stock some farm tractor parts including u-joints. that's where i got mine for an old massey-ferguson sickle mower.
sbin
04-10-2008 20:43:39
Take measurements and use google unless you need it tomorrow.I have found parts this way and saved $$$.
