Tractor Talk Discussion Forum
HIgh power rifle time to Vote
tractorfan
04-11-2008 09:58:44
asked last week about high power recomendations the choices are 270 7MM or 30-06
im thinking for 06 cus of the diff choices in rounds but thinking 7mm if i wanna go bigger game hunting down the line thanks for any advice or help
Rootsy
04-13-2008 08:33:22
 Re: HIgh power rifle time to Vote in reply to tractorfan, 04-11-2008 09:58:44
between the choices offered... the '06 would be the easiest to walk into any store and get ammunition for in multiple choices. I'm a bit off the beaten path as my 700 Mountain Rifle is chambered for 280 Remington (7 mm). Last custom rifle I built for myself I chambered for 35 Whelen AI. Shoots better than I could have ever hoped and has enough ooomph to take anything in North America. The '06 will handle most anything....
No critter other than maybe the large bears are going to know the difference between a 270, '06, 300 Winchester Mag, etc etc etc... If you put the bullet where it needs to go the critter is going to die...
NOHOG
04-12-2008 16:16:20
You got some pretty good advice above on calibers but here is the best place in the lower 48 to buy a gun. Central location to all, in the center of Kansas. Gypsum Valley Outdoor Sports,>Link
Later, NOHOG, KS :wink:
buickanddeere
04-12-2008 11:06:52
I was on my way for a taller set of boots. 1/2 at 100yards is the exception and seen only on occasion at competitive events.
5 shots with 1/4 accuracy at 300 yards is typically a 1/4 yard sized group.
Bret4207
04-12-2008 15:17:00
 Re: HIgh power rifle time to Vote in reply to buickanddeere, 04-12-2008 11:06:52
buickanddeere said: (quoted from post at 11:06:52 04/12/08) I was on my way for a taller set of boots. 1/2 at 100yards is the exception and seen only on occasion at competitive events.
I guess we'd better determine just how far his version of "300 yards" is. :lol:
Walt davies
04-11-2008 22:25:05
If your shoulder can take it go for 7 MM Rem mag. I got lots shells and casing and bullets and even some powder. Can make you some real good stuff to get down to 1/2 in or better at 100 yards.
Walt
buickanddeere
04-11-2008 21:04:18
How many people here actually hunt anything larger than a white tail/mule dear or black bear at 700 yards? Mighty few do but most like to pretend they do or will. If you are going to hunt grizzly, 500 yard elk or moose. Then get yourself a cannon. Now for the 99.999% of the hunting actually done by 99.999% of hunters. How about something that shoots ammo that is both in stock. And cheap in every rural store? That's the .22, .223, 243, 270, 308, 30/06, 30/30, 300 Winchester and 12 gauge. Want something that you can always find ammo for, them it's military calibers. .22,.223, .308 & 12 gauge. If you can't knock game over in the lower 48 states with a 308. You better stick with video games.
NE IA
04-11-2008 18:51:07
Like I tell my three sons that are forever buying new guns because of every excuse they can muster up. Want to go fetch ol bessey out of the salt barrel an go kill something or do ya wana brag about your new gun?
Any of the ones you picked out better do the job, otherwise have maw do the shootin for ya. I never help the kids plan the deer hunting mob killings ordeals, look at their areal maps, or check my watch to time my movments. I usualy have my deer the first morning, and I just go out and shoot one that gets in my way. It's usualy 99% luck, and 1% me knowing whats going on. Most of the time the kids take more time messing with me than they do shootin at the VERY VERY BIG BUCK deer they realy realy ...almost... killed. They can't seem to find my tools when the borrow them, but they can count upwards of twenty pionts on a mile away deer that I can't tell if it's a doe or a buck.
Best buy one and wish you would have bought the other one like the rest of us do.
MarkB_MI
04-11-2008 18:47:09
Which 7mm? There are a bunch, including the 7x57 Mauser, .280 Remington and 7mm Remington Magnum. Since you say you might need the 7mm for "bigger game hunting", I'm going to assume you mean the 7mm Remington Mag or one of the other magnums.
If you intend to go after bigger game than the venerable .30-06 will take down, you better get something heavier than the 7mm Mag. Think .375 H&H.
I personally am not a big fan of the 7mm Remington Mag. I'll qualify that by saying the only one I ever shot had defective scope mounts and would not hold a zero, so that did probably bias me a bit. But let's look at the numbers. I pulled out my Lyman reloading manual and here's an example:
The 7mm Remington Mag will launch a 175 grain bullet at around 2700-2900 fps.
The .30-'06 shoots a 180 grain bullet at around 2600-2800 fps.
So the difference in muzzle velocity between the big belted magnum and the old '06 is only about 100 fps! How is this possible? Well, two things come to play: First the slightly larger diameter of the .30 caliber bullet over the 7mm means that there is greater surface area for the combustion gases to push against, which means faster acceleration for a given chamber pressure. (similar to getting more force out of a larger hydraulic cylinder). The other reason is that the magnum has to use a slower powder to take advantage of its greater capacity. So it takes a larger charge of slow-burning powder to attain the the same velocity as a faster burning powder. And that heavy charge of slow powder translates to a lot of muzzle blast.
I think the 7mm Mag is a good choice for long-range hunting out west, because it shoots flat and it shoots a bullet with a high sectional density that will carry a lot of energy down range. But for ranges around 100 yards, give me a .30-06 anytime.
By the way, most rifles lose one round of magazine capacity when chambered for a belted magnum versus a standard cartridge.
RayP(MI)
04-11-2008 17:22:54
Frankly, I like 6mm (.240wby, .243 win) for deer. Reload with Nosler Ballistic tips. Far more deadly than they ought to be.....
Old Iron
04-11-2008 16:04:23
Flip a coin, and take your pick,.... the .300 Mag., 7MM Mag, 30-06, .308, .270, all have the ballistics to take deer at 400 yards "if" you can hit them.
Once you have honed your "hunting skills" (somewhat) and get tired of mundane long-range kills,.... get yourself some blackpowder, a good .54 cal. FLINTLOCK rifle, some roundballs, and start having some "real fun" hunting at closer ranges by pitting your stealth and physical abilities against those of the deer/antelope/blackbear/elk/caribou/etc. :D
Janicholson
04-11-2008 15:59:55
The ammo in question is less important than the quality and accuracy of the weapon it is fired from. A pre65 Winchester Model 70, or a Remington, or Other arms based on the mauser basic design, are great. Acurizing, loading for purpose, AND EXPERIENCE ARE MORE IMPORTANT. JimN
in-too-deep
04-11-2008 14:37:29
.30-06
kyhayman
04-11-2008 14:09:26
Personally, I use a .270, my dad and my cousin (we hunt together) both use a 30/06. I reload for all of us. Ballistically, you can use anything from a 110 grain hollowpoint up to at least a 180 grain soft point in either. We use exclusively 110 grain hp for stuff up to white tail deer size. For bigger things, use a bigger bullet (do NOT try 110 grain hp on a cow, dont ask me how I know ;-)).
I"ve found out of a Remington 700 the 270 shoots a little flatter than the 30/06. I normally put 57 grains of H4831 in the 270 and 58 grains in the 30/06 behind the 110 grain hp. Result wise, head or neck shots at up to 120 yeards are not a problem (and our house rules call for head or neck shots only) and the deer never moves.
Bret4207
04-11-2008 13:38:22
Your best bet would be getting a basic '06 with a 4x scope and spending all the rest of the money you'd spend on big expensive magnums and scopes on ammo and learning to shoot the darn thing.
Verniee
04-11-2008 13:14:29
7 mag gets my vote. You can load it up or down depending on what you are using it for. Very flat shooting.
But then again why choose? Get them all.
kmcampbe
04-11-2008 12:51:19
I used to shoot a remington 750 in 30.06 and was consistently grouping 5 rounds in less than a quarter from more than 300 yards...
Bret4207
04-12-2008 07:36:18
 Re: HIgh power rifle time to Vote in reply to kmcampbe, 04-11-2008 12:51:19
"5 shots under a quarter (about an inch) at 300 yards." My BS meter just pegged out!
Gun guru
04-11-2008 12:30:47
Armalite, AR-10 with quad rail, all stainless, composite stock. .308 caliber Oh, did I forget to say high power scope too.
All for the low-low price of about $1,800.
Billy NY
04-11-2008 12:05:45
Not that familiar with the 7mm rem mag and the various ballistics/variety of loads etc. but assume it to be higher velocity due to the lighter bullet and more powder in the casing, so in the right set up it should be a tack driver and have a longer maximum effective range, with a little smaller bullet. I have one friend who owns one, it performs well on whitetale deer as I have seen him get a few here with it.
Maybe it does out perform the .308/30-06, you would have to compare the ballistic charts to see what the actual differences are.
Not so easy to decide between those, but if one could find a heavy barrel like the savage my friend bought in .308 recently, which I have shot several times, that would have to cover most hunting applications, not sure if there is a similar set up in 30-06, with that heavy or target type barrel rifle, with a 1:10 rifling, I think it was glass bedded too, really performed well with tight groups. I will go out on a limb and mention, (please correct me) that those .308 & 30-06 are just about ballistically identical, or very much the same, just that the .308 has a 1/2" shorter casing. You have to look at the tables & charts. There is a lot of surplus military ammo available, but that may or may not be of interest depending on what you shoot and how it performs in a particular rifle. Some military brass, I think U.S. made, has thicker wall casing, berdan primed, some things to learn about the interchangability of mil ammo and non mil ammo, not sure how important but there are differences. If you look at the list of factory loads available and the same for making your own loads, there are a lot of options for these .308/30-06. I'm under the assumption that the proper loads would be effective for most North American big game, but if you are after Mule Deer, Elk, Moose or the larger bears, longer ranges might want to look further into that, max effective range and bullet energy etc. not something I'll ever hunt so the .308 is plenty for what I do.
If you need the extra power, I'd go to the .300 Win Mag., I have seen how those perform like I mentioned before. You can find the ballistics for these on the web, you should take a look and see what decent rifles they can be found in, might help you decide. The ones you are looking at are all quite impressive, just have to consider what you will be hunting.
GeneMO
04-11-2008 12:01:10
Well it depends on what you want to put down. My buddy says you can kill a deer with a croquet mallet, if you hit it in the right spot enough times.
For white tail and midwest hunting I sure like the .270. The pronghorn I shot in Wyoming never knew what hit him from 400 yards away.
For mule deer it is probably a little on the light side, as well as for elk.
Bear? never wanted to hunt something, that if I shot and wounded it, it might get pi**ed and eat me.
You might also want to consider cost of ammo and availability in your area. .30-06 might be more common and less costly.
My 2 pennies worth.
Gene
Bill in Colo
04-11-2008 11:53:30
I vote for the 7mm mag I've used one for 40+ years. I my area it is one of the more popular big game rifle.you can always find ammo in camp.
Bill(Wis)
04-11-2008 11:51:23
Lots of ballistics data available on the net. Try Remington, Weatherby, etc. They'll give you all the info you need for every round imaginable.
HossinMe
04-11-2008 11:40:29
Ive shot bout everything ever made up to a 155 howitzer,then I bought a Browning 7mm. Ican pick turkey buzzard heads off at 300 yards and Ive gotten a moose with 1 shot at about 150 yds.Im 58 yrs old and wouldnt have another gun,cept my muzzel loaders. Hoss
greg b
04-11-2008 10:22:33
i must have missed that one, what about the 300 win mag ?
Paul Shuler
04-11-2008 10:08:23
Once I got my 7mm I retired my old 06. I just love that gun. Seems to be a real tack driver compared to my old 06.
jal-SD
04-11-2008 10:08:07
An 06 will take any big game animal in NA, look at the reloading data for a 7MM & 06, they are not that different when they get out there a ways. Go for the 06. (My $0.02 worth. jal-SD)
