Tractor Talk Discussion Forum
tractor roll over`
Big Hunter
04-12-2008 13:13:28
Say a tractor rolled over onto the side the exhaust manifold is on and layed there for about 4 hours. And the engine oil ran into the exhaust manifold. Then it was set back up and sat upright for a month or so. Then the engine was started with no problems and has run like a top for say 10 times 30 minutes each time, but it smokes everytime it's run, not out of the exhaust pipe but seems to be where the exhaust pipe and manifold meet. What should I do? Just keep running it until it's all burnt out of the manifold? Thanks
RodInNS
04-12-2008 18:43:43
 Re: tractor roll over` in reply to Big Hunter, 04-12-2008 13:13:28
Run it. Will clear eventually.
Steven f/AZ
04-12-2008 14:48:49
Set it up for a good pull to get some heat going in there to burn the oil out.
Janicholson
04-12-2008 13:58:24
I, also, would run it. IF THERE IS DRAMATIC smoke, I would be cautious of fire. JimN
IaGary
04-12-2008 13:26:28
It will burn out sooner or later.
I would run it.
Gary
DickL
04-12-2008 13:20:23
That or take the manifold off and wash it out. I myself would let er smoke until it quit.
