Tractor Talk Discussion Forum
old lawn mower
DENNIS CHAMBERS
04-13-2008 07:39:58
third party image
i know this is a tractor forom but i was wondering if someone could tell me what kind of mower this is and if any body knows where i can find one. thanks.
Boyd in Mn
04-13-2008 21:49:26
 Re: old lawn mower in reply to DENNIS CHAMBERS, 04-13-2008 07:39:58
They were made yet into early this decade. Only one specific engine was on the market made to have a pulley on the top and bottom. Top pulley goes to the drive,, bottom pulley goes to the blades. The engine would not pass the new emissions standards for lawn equipment and thus was discontinued and they had to stop making that mower. I think the engines on them were Tecumseh.
GeneMO
04-13-2008 19:48:02
These were manufactured at Warrensburg Mo. My dad was a "jack legged" dealer, basically bought stuff for his own use. I have a few new, old stock parts, mostly belts and bearings.
Gene
bradk
04-13-2008 16:07:45
Big Mow.Got one in the shed like it.
Strange contraptions.
the Unforgiven
04-13-2008 16:03:26
Swisher Big Mow or Ride King. I have used them a lot, bought one of the later ones new with the fiberglass hood, electric start, and variable speed drive about ten years ago, still using it. Really liked the older one's like yours better. Many of them had the starter that you would wind up and then trip, and they also had a 110 volt starter that you plugged in and fired it up, handy for that first light of the spring. They are no longer made. I have a good one just like yours but it is a Gambles, lime green and white. Before everybody had a zero-turn, they were a really fast mower just because you didn't waste any time turning. Really handy once you get used to them, if you have a rough yard they suck because of the rigid deck.
rodgernbama
04-13-2008 14:42:48
It"s a Swisher Ride King. I bought one new in 1986 for $625.00. Used it till 1999. I gave it to a guy that bought a 9n from me. They changed the sheet metal design on the later models. I"m not sure if they are still made. It has a single zero turn wheel on the front that is chain driven. Only thing that went wrong with mine was the Tecumsh engine that broke the piston skirt. You could get them with a Briggs engine also.
Walt davies
04-13-2008 10:29:29
Maybe this will help you.
Walt
third party image
Don L C
04-13-2008 09:12:17
Dennis ---
Go on down to " GARDEN TRACTORS " they also talk lawn mowers.....a lot of information there..... Don
UncleTom
04-13-2008 09:11:35
They were sold under a few different names but Big Mow is one of them.
flying belgian
04-13-2008 10:42:10
 Re: old lawn mower in reply to UncleTom, 04-13-2008 09:11:35
yep. Big Mow. Pa bought several of them. Most had a 2 speed selected by tightening a different set of belts. They were kind of troublesome. Some had tecumse and some had briggs. The briggs were a better engine back then. bearings were always going out in all those pulleys. They were zero turn and you backed up simple by turning the front drive wheel all the way around with the steering wheel. The concept was all right but they sure did not hold up very well.
