Tractor Talk Discussion Forum
641 with a finish mower?
88s
04-16-2008 14:19:05
I was thinking about buying a new John Deere riding mower with a 50 plus inch deck but they are expensive.My dad has a nice 641 Work Master Ford that I would like to buy from him.Would a 641 with a 6 ft finish mower(a GOOD one)be a good choice over a large size lawn mower?Do any of you run this kind of set up and how well do you like it?I have a 3 acre yard.
soundguy
04-17-2008 06:12:24
 Re: 641 with a finish mower? in reply to 88s, 04-16-2008 14:19:05
An 8n will spin a 6' finish mower.. a 641 ( kind alike an updated NAA ) should make short work of a 6' finish mower. Good combo..
soundguy
Bill Hufnagel
04-16-2008 17:32:04
Should work fine,I bought a Walco-Douglas Finishing mower last year and do as nice of a job as a regular riding mower. Has plenty of suction to pich up the grass in the wheel tracks and leave no un-cut areas.
Mike in Ohio
04-16-2008 16:47:35
I have run a 6' finish mower with an allis chalmers b 22-24 horsepower. Plenty of power only problem I had was the b is very light in the front end and when I would lift the mower it was always a guess whether the mower or the front end was gonna raise up off of the ground. I don't think you will have as much problem with that on the 641 because it sits much lower, but that is a guess. Besides you will look much cooler on an old ford than a new jd. Good luck deciding, Mike
KEH
04-16-2008 15:57:32
Finish mowers work fine and that tractor should have no trouble with it. A good quality finish moer will cut fast and clean.
Disadvantages: If you have a lot of bushes, flowers and trees to cut around, the finish mower will cause you to do a lot of double cutting and turning. If you have to back it up a lot, it may get tiresome, but you can back the thing under a lot of bushes and low trees.
Hooking it up and taking it off gets old fast.
KEH
Fordfarmer
04-16-2008 15:30:54
Would be a good set up. My uncle runs a 5' finish mower on his 8N- with power to spare. 8N is 26 h.p., 641 is 32 h.p., plus live hydraulics. Set the tires in to 6' or less and go for it.
Kevin in OK
04-16-2008 14:33:50
I don't have much experience with finish mowers but a bunch of people say the 8N will run a finish mower. The 641 has an extra 6 hp or so, a lot more weight, live hydraulics, and is just a better machine. I think it would be an excellent match, but ilke I said, I've never used one. So I could be wrong.
My grandpa's Ford 631 (basically same tractor, with PTO as option) will run a 5' Brush Hog just fine, if that means much to you.
Kevin
