Tractor Talk Discussion Forum
MF - 135 Diesel Misfiring losing power when hot.
Bushboy
04-17-2008 09:35:11
Hi Guys
I"ve searched all related topics and couldn"t find symilar problems to mine. My MF135 Diesel is an ancient, oil and mug covered machine, with no lights, guages or trimmings but a true workhorse! It"s starter solenoid activates by the 3rd time you push the button and only the left brake works. BUT... it ALWAYS starts like clock work and runs like a swiss watch, come rain, frost or sunshine.
Recently she started to misfire and lose power when hot and only when hot. If pulling a big load like a road scraper she"ll start misfiring, lose power and obviously slow down, BUT.. just before she dies the 3rd cylinder kicks back in, gain power accelerate and repeat the symptom.
I had a theory obout a broken valve spring as the problematic valve gets chance to close at low rpm"s but leaks at high rpm"s. This could have been made worse with temperature. But I"ve opened the top cover and all looks fine. Neither the valves nor the pushrods are sticky.
I realy don"t have the finances to do an overhaul nor do I think its neccesary as she was fine till recently. Furthermore I can"t afford downtime as I need to start on the fire roads for the winter.
Any help will be much appreciated.
Thanks for this forum guys!
RodInNS
04-17-2008 19:37:38
 Re: MF - 135 Diesel Misfiring losing power when hot. in reply to Bushboy, 04-17-2008 09:35:11
Have you changed the fuel filter? If not, do. Problem will probably go away. If not then clean all the low pressure lines and the tank/outlet/screen.
I'd bet on a fuel problem....
Rod
sbin
04-17-2008 16:50:38
Diesel problem usually is fuel or compression related.Wouldn't hurt to change the fuel filter, add some fresh fuel, diesel kleen or other fuel conditioner and run it hard to see if poor fuel or bockage was a problem.If a compression check shows the cylinder to be within range having injectors rebuilt and pop tested is a good idea.After that it starts to get $$$$.INjector pump, engine work.
guido
04-17-2008 15:44:54
Hello Bushboy.
It sounds like a tight valve to me. You need to check the valves for the proper clearance.You need to check them with a feeler gauge to make sure that they are adjusted correctly. Head gasket leaking water into the cylinder will make it miss also. You did not say if it smokes while it is missing? If it is water it would have white exhaust smoke, and with antifreeze in the cooling
system it would have a sweet smell.
Guido.
RAB
04-17-2008 11:54:33
Bushboy,
Simple things like filters or a partly blocked fuel outlet from the tank. Could be an injector is in need of attention. Could be a blocked spill return on one injector.
Must be fairly simple fault, like a partially closed tank valve or above or it would not recover like you say.
Regards, RAB
