Tractor Talk Discussion Forum
International 340 DU
kmm1933
04-21-2008 13:32:56
Do you have to drain transmission fluid to change hydralic filter?
Russ from MN
04-21-2008 17:31:49
 Re: International 340 DU in reply to kmm1933, 04-21-2008 13:32:56
When I changed mine a friend told me to run the right rear tire up on a block of wood to tip the tractor some and then I didn"t have to drain out more than 3-4 gal. The first couple of quarts didn"t look to good so I didn"t put it back in, added some new instead. good luck!
