Tractor Talk Discussion Forum
Pressure Plate...Bad???
Tweeter
04-22-2008 19:32:22
The clutch in my JD tractor is shot for sure but how do I know whether or not the pressure plate is bad and needs replacing?
El Toro
04-23-2008 07:58:08
 Re: Pressure Plate...Bad??? in reply to Tweeter, 04-22-2008 19:32:22
You can contact Carolina Clutch & Brake. They may be able to rebuild your clutch. They do farm tractors. Hal
1-800-374-2212
buickanddeere
04-23-2008 07:27:39
Two cylinder Dubuque, two cylinder Waterloo, Waterloo, Mannheim or Yanmar dry clutch or Perma-Clutch?
RobMD
04-22-2008 19:56:54
pressure plate springs get weaker and weaker as the disc shrinks in thickness. Sometimes, you can reuse a pressure plate. But nowadays, I put in everything new. No sense in putting one of this and nothing of the other.
RodInNS
04-22-2008 19:46:43
I spose that would depend somewhat on the tractor. I dunno about the 2 cylinders, but if it's a later, more conventional tractor then just look at the plate. If it's grooved up or the PTO drive hub splines (if it has one) are bad, then you would replace it.
Generally speaking, I think if you let the clutch go to the point where it was completly useless and slipping to the point where there was no drive, then the PP should be changed anyway and the flywheel ground to remove the grooves from it.... that's if you want the clutch job to last.
There are always rare instances where you would get away without that, but not many.
Rod
