Tractor Talk Discussion Forum
Making steel bushings and rod-ends
jdemaris
04-23-2008 11:51:47
Does anybody know of a good source for steel bushing stock? It's somtimes called "bushing stock", sometimes called "structural steel tubing", etc.
One example. My Deere bucket has many 1 1/2" ID pinholes that were fabricated from some sort of heavy-wall steel tubing - cut off in slices and welded on at the factory. 1 1/2" ID and 2 7/8" OD. If I had a length of this material, I could saw off new bushings and weld them on - to tighten up the bucket. I think many rod-ends on hydraulic cylinders are made the same way.
I've tried my usually sources, e.g. Enco, MSC, Mcmaster-Car, etc. and didn't find much. Closest thing is with McMaster - they have lengths of heavy-wall structural steel - 1 1/2" ID and 2 1/2" OD. $60 per foot.
I run into this sort of thing often with backhoes and loaders. I figure many fabrication shops buy this stuff in quantity - and I'm looking for a source to buy in something like 1' or 3' lengths.
Heat Houser
04-23-2008 18:56:51
 Re: Making steel bushings and rod-ends in reply to jdemaris, 04-23-2008 11:51:47
third party image
Go to any steel supplier and ask for DOM tubing.
DOM is "Drawn Over Mandrel" hence, the DOM name. This tubing will be a few thousands over nonimal size so if you order 5/8ths, it will slip over 5/8 round. I just got some 5/8ths to use to make a deer food plot planter out of a 1240 JD row unit.
I buy mine from: Storm Steel 6105 6th St Sw, Cedar Rapids, IA (319) 362-0522
Oldmax
04-23-2008 17:27:23
You can get Seamless tubing in sch 40 is most common . Also comes in 80 - 120 -160 . The outside stays the same the hole gets smaller. I used to work for piping supply Co .
Texasmark
04-23-2008 15:42:04
I have had the same problem in the past. For me, twas time to cut off the rigid and install hydraulic hose.
Mark
Gerald J.
04-23-2008 14:08:21
Des Moines Iron and Supply, 123 S.W. 3rd. Des Moines, Iowa stocks bushing stock.
(515) 243-0177
Its over on the outside and under on the inside, made for finishing to size with a lathe inside and outside. It is a steel that does machine nicely with lathe or tool post grinder.
Gerald J.
jdemaris
04-23-2008 17:01:08
 Re: Making steel bushings and rod-ends in reply to Gerald J., 04-23-2008 14:08:21
Thanks.
That sounds like the stuff. Leaving it a bit undersized would allow an align-boring and finish sizing. I have to check them out and see if they'll sell in small quanities.
Gerald J.
04-23-2008 19:10:39
 Re: Making steel bushings and rod-ends in reply to jdemaris, 04-23-2008 17:01:08
I've bought by the foot. Costs for the cuts unless they have some pieces left over from a previous customer.
I know Randall Machine and Welding stocks it too, but he is only open Fridays and Saturdays. He gets from Des Moines Iron.
Gerald J.
smurph72
04-23-2008 13:44:52
I used to haul material for Tubular Steel, based in St Louis, MO. They have all sizes and shapes of tubing round and square. Might have what you need? Hang on to your hat on the prices though.
dcm
Paul from MI
04-23-2008 12:12:12
Don't know where you're located, but google "Alro Steel". Several locations here in Michigan.
Paul
trucker40
04-23-2008 12:06:48
There is double strength pipe,and triple strength pipe.If regular pipe is about 1/4 inch thick,double strength is 1/2,or triple is 3/4 thick.
benny2
04-23-2008 12:03:39
 What you are looking Re:Making steel bushings and rod-ends in reply to jdemaris, 04-23-2008 11:51:47
What you are looking for is called Shelby Tubing. This stuff can be had in many wall thickness from metal suppliers that supply to machine shops. It comes in various alloys. For pin bushings 4140 works the best. The other low chrome alloys can be case hardened in situ by Kasenitt.
