killing small pines
TJAllen
04-24-2008 18:05:42
The slope leading down to my driveway has about 1000 1 and 2 year old pines and I want them out. Will Roundup kill them, or do I need something else.
Tim
James Howell
04-25-2008 10:26:56
 Re: killing small pines in reply to TJAllen, 04-24-2008 18:05:42
I use a pair of "loppers" and cut them flush at the ground. The pine is very soft wood.
The good thing is that they will not "sprout up" from the tap root; once they are cut they are dead.
Do not mow with a rotary cutter ( bush hog ).
You will create "tractor flats" that will have to be cut flush to the ground with loppers.
Alot of work but you are done once and for all.
Nancy Howell
04-25-2008 10:06:55
I have used remedy successfully on persimmon seedlings. The larger the tree, the harder to kill. I have used remedy on bull nettle and it also killed the grass.
jbmac
04-25-2008 09:18:39
Use a triclopyr 4 product like tahoe or remedy or garlon. It"ll smoke pine trees and should"nt hurt grass below them. It will also wipe out poison ivy and cactus when mixed with crop oil or diesel(20% triclopyr, 80%oil/diesel), spot treat only, may damage/kill grass.
greygoat
04-25-2008 07:47:19
Dog Pee will kill pine trees!!!!! !
TJAllen
04-25-2008 04:53:49
These are northern White pine. There in a spot that I can't brush hog, to steep and rocky. Think I'll try some roundup and 2-4-D and see what happens.
Tim
Leland
04-25-2008 20:31:19
 Re: killing small pines in reply to TJAllen, 04-25-2008 04:53:49
your wasting your money on round up and 24D you need a brush killer .
2x4
04-24-2008 22:58:24
some pine trees won't sprout back. Better find out what they are before you select a treatment.
Leland
04-24-2008 20:55:01
crossbow and diesel fuel will stop growth
Dachshund
04-24-2008 19:25:47
Brush hogging them won't kill them. It will just cut them off. If you don't mow it for a year, they will come back. The best way is to use a brush killer, or get out there and cut them as close to the ground as you can.
IH2444
04-24-2008 18:15:14
I suppose roundup will kill em. but bush hogging them down and keeping them bushhogged will do the same thing. Won't more just come up ? roundup will kill pretty much anything you put it on except some darned cactus I have....
john in la
04-24-2008 19:53:11
 Re: killing small pines in reply to IH2444, 04-24-2008 18:15:14
IH2444 said: (quoted from post at 18:15:14 04/24/08) roundup will kill pretty much anything you put it on except some darned cactus I have....
I got some poison ivy that just laughs when you spray roundup on it.
Gives it more room to grow because the roundup just wiped out any competition.
As far as the pine trees go..... ..... ....
If you live in the southeast the only way to kill pine trees and keep them out of a place is to graze it or cut it with a mower.
Even if you kill the original trees new ones will grow in its place.
