Tractor Talk Discussion Forum
HELP with Magneto
Coltond202
04-25-2008 13:17:51
Im part of a student group restoring a 29 John Deere D for the Nebraska Test Lab museum. A rebuilt splitdorf magneto was donated a few weeks ago but it will only spark on the left cylinder. All of the brushes look new along with the points. What could the problem be. When we turn it over theres a good snap and spark on the left cylinder, on the right theres a little click and at the points a very faint spark once in a while. Any suggestions would be helpful.
Coltond202
04-26-2008 00:14:11
 Re: HELP with Magneto in reply to Coltond202, 04-25-2008 13:17:51
Took it all apart, put it back together works like a charm. Thanks for the help.
NE IA
04-25-2008 16:48:38
Are you mounting it and getting no spark or is it on the work bench? If it is on the tractor I would double check for binding on the coupler? Just a long shot here. The next thing could it be a bad bushing / bearing?
Mathias NY
04-25-2008 14:37:16
Did you try swaping the wires and plugs to make sure that isn't the problem?
Coltond202
04-25-2008 14:42:20
 Re: HELP with Magneto in reply to Mathias NY, 04-25-2008 14:37:16
I tried everything I thought I tried switching the wires. I dont even have a spark at the points on the right cylinder
garytomaszewski
04-25-2008 14:58:01
 Re: HELP with Magneto in reply to Coltond202, 04-25-2008 14:42:20
You said a click on the weak spark side, I think you should make sure the impulse is catching a tripping.
