Tractor Talk Discussion Forum
john deere m starter
kwh
04-26-2008 18:13:58
I think my starter has gone bad on my 48 jd m. Should I replace the 6 volt with a 12 volt and change the generator over. How expensive is to rebuild a starter.
Maark
04-27-2008 07:15:00
 Re: john deere m starter in reply to kwh, 04-26-2008 18:13:58
Your 6 volt starter is built heavier than a 12 volt. If you would change it over to 12 volt, use your 6 volt starter.
gene bender
04-27-2008 01:36:07
Just get a rebuilt one from HARVEY BROS probably will run 125 or so it will have a new BENDIX and warranty then some 1ga cables probably a new 720A battery. Tractor is 50pluss yrs old and needs to have good stuff to operate good if it aint worth fixing rite give it away.
buickanddeere
04-26-2008 20:04:17
It's started just fine this long on six volts. The starter just needs a normal cleaning up,turn the com, fresh bushings, a new bendix. Scrawny little #4 cables for 12V don't work here. It needs 2/00 cables and a 800CCA or larger battery. Run the + chassis return cable to the bolt the starter mounts on. If somebody has swapped polarity of the battery or coil. It will suffer a weaker spark and therefore poor starting.
Russ from MN
04-26-2008 18:34:48
 Re: john Deere m starter in reply to kwh, 04-26-2008 18:13:58
I think the starter will last longer on 12V than 6, so I have heard and experienced. But if you get it repaired properly, it will probably last a long time. Also, I don't think an alternator would fit under the hood, and they look bad hanging out. We have an M and it turns over easy and starts instantly on 6V! good luck!
old art
04-26-2008 19:41:56
 Re: john Deere m starter in reply to Russ from MN, 04-26-2008 18:34:48
take the starter off and take it apart it may only need brusher and cleanning if there is a bigger problem put it in a box and take it to the rebuilder you cant hurt it. auto parts store will have brushes probley a delco starter.
