Tractor Talk Discussion Forum
keep it simple
jay-eye-see
04-28-2008 12:03:47
How do i know if my TRACTOR tires have air in em ??
Walt davies
04-28-2008 15:43:40
 Re: keep it simple in reply to jay-eye-see, 04-28-2008 12:03:47
If you are wondering whether it is straight Nitrogen or Air then let a little out and smell it. Try other tires to see what the difference is. Most likely its just air.
Walt
preacher bob
04-28-2008 22:54:21
 Re: keep it simple in reply to Walt davies, 04-28-2008 15:43:40
you are joking right? see if it smells different??
hahahahaah
NE IA
04-28-2008 14:23:19
With all due respect to the other posts. It seems often I am on the other side of the fence but here goes. I personaly will never check the air in a tire if it may have cloride in it as you may indeed have problems sealing off the valve stem.
And also just because a tire is standing tall means no guarentee. A tire with fluid may stand somwhat tall, but still be low on air pressure. Many tires are tore to shreds by having fluid and runing low on air pressure. It will tell you this by a small sidwall bulge that experiance folks can pick up on.
However all and all you have good odds that you will have to check the air presure, and you simply have to check it at the valve stem. I guess I should state that it is best to not mess with it if your project is a hour from being done or so. If they look good wait untill a rain day so you can play games with it while it rains. Not exactly like if it ain't broke don't fix it, but a close second to that statment. After you get used to the tractor you can pretty much tell by looking. Running a low tire tends to flex or fold the rubber and this is what causes the tire failure. Some of the old farm mags had pictures showing the different problems.
thurlow
04-28-2008 12:18:23
I don't know how to tell if they have "air" or nitrogen; I'm sure those are the 2 choices.
mjbrown
04-28-2008 12:13:18
Well... if they don't have a flat side on the bottom they have air in them. If you want to know if they have 100% air or air+ liquid ballast, let a little air out the stem with the stem at the bottom or look for condensation on the tire on a warm humid day after a chilly night. The liquid ballast will stay cool for a while and water will condense on the tire as high as the ballast goes usually about half way up.
