Tractor Talk Discussion Forum
distributor firing order(ford 800)
ronnie campbell
05-02-2008 19:58:52
looking at the distributor, where is #1 located at? I know 1-2-4-3 is the order of the spark plugs, but how it the order on the distributor. i may have mix up my wires and wanting to know the number of the order on the cap its a 172 motor
El Toro
05-03-2008 09:55:47
 Re: distributor firing order(ford 800) in reply to ronnie campbell, 05-02-2008 19:58:52
Once you get No1 piston to TDC on the compression stroke and see where the rotor is pointing connect
your wires in one of these firing orders. Hal
PS: Note the direction the rotor turns.
3-1
4-2 CW
1-3
2-4 CCW
Note: Your rotor may not point where I have No1, then just move the plug wires around & start with No1, then2, then 4 & No3
MarkB_MI
05-03-2008 02:37:50
Just as important as the location of #1 is the direction of rotation. I can never remember if it's CW or CCW, but take off the distributor cap and check. I ran mine for several months with the firing order reversed; you couldn't tell that two cylinders were missing other than it didn't have much power.
Keith-OR
05-02-2008 21:24:05
Pull #1 spark plug, put your finger in the hole, crank engine over untill compression blows your finger out the spark plug hole. Then check and see where the rotor is pointing, it should be pointing at #1 plugwire on your distributor cap.HTH
Keith & Shawn(Special Olympic Gold)
old
05-02-2008 20:19:39
That all depends on where some one has drop the distributor in. I most it can be doped in any place. So what you need to do is get #1 a TDC and look to see where the rotor is. Then hook up the wires from there. Also when your getting it a TDC watch to see which way the rotor is turning
