Tractor Talk Discussion Forum
farmall 460 pulling tricks
Dylan Dahlheime
05-03-2008 12:11:46
Does anyone know how to make a 460 pull better without doing anything big to the motor..... . govenor, carb., hitch, air cleaner..... If you know anything, please respond
garytomaszewski
05-03-2008 21:12:46
 Re: farmall 460 pulling tricks in reply to Dylan Dahlheimer, 05-03-2008 12:11:46
All the old hot rod tricks; port matching and polishing, manifold polishing, timing advance(with better fuel to combat pre-ignition), dyno tune the carb, loose the muffler, anything to help the engine breath easier, little model airplane fuel(nitro methane) in the fuel, smaller tires on the front, proper hitch height,right air pressure in the rear tires to match the track, etc..
flying belgian
05-03-2008 19:10:31
By pulling better do you mean pulling more total weight or pulling less weight faster? If you want to pull more total weight than add weight to tractor and shift down. If you want to pull less weight faster then put bigger tires on rear and smaller tires on front to get your tractor leaning forward as much as possible. That only helps if you are pulling from drawbar instead of 2 pt.
Dylan Dahlheimer
05-03-2008 19:43:30
 Re: farmall 460 pulling tricks in reply to flying belgian, 05-03-2008 19:10:31
we would pull 6000 or 7000, but do you know any tricks to get more horse...
Wesley Stephens
05-03-2008 16:46:06
fill the back tires up with water, make sure your carburetor is properly adjusted, check timing, etc... What are you using it for? That might help folks to provide better advice.
Dylan Dahlheimer
05-03-2008 19:44:28
 Re: farmall 460 pulling tricks in reply to Wesley Stephens, 05-03-2008 16:46:06
do you know any quick tricks to get more horse and still pull stock, but cheat a little...
Dylan Dahlheimer
05-03-2008 19:42:32
we just want to pull stock, but win..
Dairy Farmer in WI
05-04-2008 05:19:56
 Re: farmall 460 pulling tricks in reply to Dylan Dahlheimer, 05-03-2008 19:42:32
no offense but have fun with that. i pull stock tractors just for fun and i never get anywhere near winning. with all these people souping up their tractors to run twice the stock power and are still pulling in outta-the-field classes. although i do have to say last year i did beat a souped up JD G ;). he ran outta alcohol or whatever he was runnin' through that thin.
alls i'm saying is that there is just no cometition for stock tractors in pulls anymore.
DF in WI
