Tractor Talk Discussion Forum
john deere 7020 rear brakes
francis pawelek
05-04-2008 07:32:32
where are these located exactly,also since i recently had the rear end torn down,i didn't see them antwhere near the rear end area,could they be inside the axles ?
Bob
05-04-2008 09:15:31
 DEERE 7020 rear brakes diagram in reply to francis pawelek, 05-04-2008 07:32:32
If this is the old 4X4 from the 70's (I'm NOT sure if DEERE has recycled THAT model #), the brakes are made like IS:
Third Party Image
francis pawelek
05-04-2008 11:24:24
 Re: DEERE 7020 rear brakes diagram in reply to Bob, 05-04-2008 09:15:31
looks like maybe only the right side has a plate if i'm not mistaken though,heck 1 brake plate like that ought to slow it down anyway,but what if my brakes are just stuck like i think it is ,i cant push the pedal down right now
Bob
05-04-2008 14:44:01
 Re: DEERE 7020 rear brakes diagram in reply to francis pawelek, 05-04-2008 11:24:24
There's brake assembly on BOTH sides. If your pedal is stuck, either the pedal pivot is rusted up, or the brake valve needs an OH.
MSM
05-04-2008 08:45:07
 Re: john deere 7020 rear brakes in reply to francis pawelek, 05-04-2008 07:32:32
They are the same place on them that they would be on a 4020,just inbound of the planetaries,in the trans case.If I remember correctly,the 7020 rear end is the same as a 4620.
francis pawelek
05-04-2008 08:47:49
 Re: john deere 7020 rear brakes in reply to MSM, 05-04-2008 08:45:07
how would be easiest to get to them,,,pull the axle?i'm getting a silvery colored hydraulic fluid,be back after while
Bob
05-04-2008 10:21:01
 Re: john deere 7020 rear brakes in reply to francis pawelek, 05-04-2008 08:47:49
There no "EASY" way, just one way... pull the complete final drive/axle.
francis pawelek
05-04-2008 11:19:46
 Re: john deere 7020 rear brakes in reply to Bob, 05-04-2008 10:21:01
thanks bob not hard at all,,,but 1 on each side?how do you know which side?
Bob
05-04-2008 16:24:18
 Re: john deere 7020 rear brakes in reply to francis pawelek, 05-04-2008 11:19:46
There is an EXTERNAL steel brake line going to each brake.
I don't know if it is possible the 7020 only has one, as I am more familiar with the 2WD and the 84/86 30 and 40 series, which use two.
