Tractor Talk Discussion Forum
Grease zerks
Dan-IA
05-04-2008 16:18:03
I have two grease zerks that have been broken off. Initially I thought they were rollpins in a kingpin, but there's a greasegun decal there and there's no hole on the other side. I would like to remove whatever is left of the zerk in the hole. Would an easy-out get it out, or should I try drilling? pb blaster?
I'm clueless on this one. I'd appreciate your advice.
greygoat
05-05-2008 06:48:24
 Re: Grease zerks in reply to Dan-IA, 05-04-2008 16:18:03
Remember: some zerks do not screw in, but are
driven in-that is, the don"t have threads but
just serreted ridges.I have some like that in
a kit of zerks.
skycarp
05-04-2008 19:31:48
Northern Equipment sells a tool kit to do just what you want to do. Cheap too.
IH2444
05-04-2008 16:56:37
I would try the easyout first. Less shavings going where grease should go.
Mark - IN.
05-04-2008 19:53:54
 Re: Grease zerks in reply to IH2444, 05-04-2008 16:56:37
Me too. Will probably be all that he needs to do. Have done so in the past. Tap, tap, tap, turn out, replace.
Mark
steelfronts
05-04-2008 16:35:11
If you try drilling use left handed drill bits. Sometimes the threads will stick on the bit and spin out. If theey dont ther's always the easyout
