Tractor Talk Discussion Forum
Mfarmall reat tire size
WBrookins
05-04-2008 17:14:12
Can someone tell me what is the correct rear tire size for a M Farmall tractor.
james rumph
05-04-2008 17:45:00
 Re: Mfarmall reat tire size in reply to WBrookins, 05-04-2008 17:14:12
I own a 52 Super M and the direct factory replacement tire size is 16.9 - 38 from the show room they were 15.5 - 38s but they went with the 16.9s later.
This info is from a 60 year old Internatioal dealership in Michigan that sold them when they were new .
12.5 i don't think so maybe a cub.
Andrew Z
05-04-2008 17:51:39
 Re: Mfarmall reat tire size in reply to james rumph, 05-04-2008 17:45:00
You beter check your data James, The staight M was 12.4's the Super M was 13.6. old numbers would be 11-38 for the M and 12-38 for the Super M. Look in the books there is no way they came with 16.9's that was not even an option!! You may have been looking at a 560 flyer?
Andrew
cadet trooper
05-05-2008 15:15:07
 Re: Mfarmall reat tire size in reply to Andrew Z, 05-04-2008 17:51:39
I agree 12.4's were stock our SMTAD had 13's which I thought were awesome our regular M had 12.4's I've only seen 15.5s on the 450 and bigger the 706 had 16.9X34s my opinion is you need to change the diameter when you get wider unles you match the fronts or you'll be running downhill.Post this on the Farmall forum and I'm sure someone can set it straight.
Andrew Z
05-04-2008 17:23:38
Stock size is 12.4's
Andrew
