Tractor Talk Discussion Forum
IH guy's..help
Lumpy
05-06-2008 14:31:55
Neighbor has a 1486 with hyd issues. Start tractor. Power steering works, clutch works, brakes, etc.
Now, push the clutch in, put it in gear, start letting clutch out and everything quites working. Engine stays running and he has tried this at several different rpm's. Any suggestions would be helpful. BTW the local CIH dealer is stumped. Thanks!
cobroller
05-06-2008 15:05:50
 Re: IH guy's..help in reply to Lumpy, 05-06-2008 14:31:55
have him engage the pto while all the hydraulics are working and before he puts the transmission in gear. If it quits turning after he puts the tractor in gear the splines in the center of the pressure plate are stripped and also on the shaft. Fairly common problem.
