OT, Mercury outboard
john *.?-!.* cu
05-06-2008 19:24:22
My Uncle has a Mercury 110, 9.8hp motor he needs to replace the spark plugs in, but neither one of us can figure out how to remove the motor cover. any help would be appreciated.
john *.?-!.* cub owner
05-07-2008 05:51:24
 Re: OT, Mercury outboard in reply to john *.?-!.* cub owner, 05-06-2008 19:24:22
oops, that was supposed to have said his "thanks"
05-07-2008 05:50:34
Uncle Bob sends his thinks for the info to all of you. As I have said many times, not only are antique tractor people the most willing to help people in the world, but also the most knowledgeable.
visito
05-07-2008 05:20:30
I have two of these...there is a pair of levers at the back of the engine under the cover lift these up and the cover lifts up and off from the back
huntigreen
05-06-2008 20:30:59
this is a 2 piece cover i think. there should be a knob on the front that you remove then 2 snap locks you release. This will be the case if it is a metal cover.
Leland
05-06-2008 19:35:50
In the front under the recoil there should be a release see if the brand label pulls open
