Tractor Talk Discussion Forum
Drill bitt
Dumb
05-07-2008 05:06:44
What size drill bitt do I use for 5/16 tap?
dave guest
05-08-2008 21:19:24
 Re: Drill bitt in reply to Dumb, 05-07-2008 05:06:44
Drill press or shaky hand? Makes a difference. Use chart for a start, then make up your mind. If hold is too big, will strip out. If too small tap may break or become too tight to turn.
Dave_Id
05-07-2008 14:16:52
Rule of thumb. Tap drill size= diameter minus the pitch.
Don-wi
05-07-2008 13:48:00
If you don't have a F drill, you can use a 13/64 drill and it'll turn out just the same.
Donovan from Wisconsin
Areo
05-07-2008 15:24:31
 Re: Drill bitt in reply to Don-wi, 05-07-2008 13:48:00
That's 17/64 Don. 13/64 is used for 1/4 -20
Areo
Walt davies
05-07-2008 07:30:34
NC or NF enquirering minds need to know???
Walt
Kentb of SWMO
05-07-2008 06:03:28
Size "F" which if my carbon based RAM is working tight is .257 inchs.
Kent
glennster
05-07-2008 05:25:07
here is a link to a chart for bit sizes for taps.
IaGary
05-07-2008 05:12:52
Size F is what I use.
Gary
