Tractor Talk Discussion Forum
King Kutter Brush Hog
Andrew Z
05-07-2008 05:42:51
How do i change the oil in the gear box on this hog? I see the fill and check pug but i cant seem to locate the the drain pug?
Thank you
Andrew
Leland
05-07-2008 18:21:39
 Re: King Kutter Brush Hog in reply to Andrew Z, 05-07-2008 05:42:51
most I ever used changed there own oil
Andrew Z
05-07-2008 17:30:44
Thanks guys i guess i will just top it on off. The unit was made in 94 and has not been used since 2000, and before that was only used to mow 4 arces of hay feild, so there is not much wear at all. I have never had one before so i waanted to see what most guys are doing.
Thank you
Andrew
Mathias NY
05-07-2008 07:45:15
Unless the fluid looks milky I wouldn't bother changing the fluid. Maybe once every 20-30 years if it gets used a lot, otherwise it's probably not worth the effort. Standing the mower up vertically will probably work the best, then the full-level plug will work as a drain.
Billy NY
05-07-2008 11:16:01
 Re: King Kutter Brush Hog in reply to Mathias NY, 05-07-2008 07:45:15
Kind of a judgement call on changing it, mine was like a coffee milkshake when I got it, leaked out the cover up top, tightened that, even broke a bolt, extracted it out and replaced,no more leaks, but that grass soaked oil on the deck sure burns nice, that lube was really nasty. Splash lube system, I'd lean on changing it more often, say if you had one since new especially at the beginning of each season or at recommended hours. Hard to say whether it will ever make a difference on wear, whose measuring that, but makes you feel better, yep fresh aaaawwwwllll in that thar gear box ;).
Will be interesting to see what it looks like since changing it last year, it does not hold much, always water in these things that is why I change it and is what must turn it to a coffee color.
Billy NY
05-07-2008 07:36:20
I used the front end loader to flip mine over, change blades, tighten gearbox to deck bolts etc., I can set it so the filler plug is a drain when upside down, at the lowest point, just found an old lifting eye/tie down from a '55 ford truck that was made into a trailer, will weld same in appropriate place on deck to make an easy pick point. If no loader, just vacuum/suction it out like Allan said, maybe flush, repeat, did mine last year, it sat upside down for awhile as I did all the repairs it needed. If using an electric drill type pump, remember not to pump anything flammable, if flushing, I like flipping mine over and draining, next time will do after mowing.
Considering that they sit 1/2 the year, condensation accumulates, and the work that gearbox does along with all the shock loads, it's a good preventative maintenance thing, mine calls for a 00 or 0 lube that I can't get in small quantity, so I used lucas 90 wt, check your book to see what is called for, also check to see of the outer gearbox shaft seal is leaking when turned over, suspect mine might be, little maintenance goes a long way on these mowers there is not much too em, and they do a ton of work.
Walt davies
05-07-2008 07:25:22
That oil will out last the brush hog just keep it full and don't worry about it.
Walt
coloken
05-07-2008 06:46:51
Never knew any body to change the oil befor.
Bob
05-07-2008 06:11:24
On some of those gearboxes there are bolts going up from the bottom that retain the seal and/or bearing housing. Try removing one of the bolts, and see if the oil drains out.
Works on my OLD TSC unit, anyhow!
IaGary
05-07-2008 05:50:45
Did you look underneath where the blades hide?
Gary
Allan In NE
05-07-2008 05:46:51
Have you a suction gun?
Allan
