Tractor Talk Discussion Forum
O/T: '98 Bravada fuel pump
MeAnthony
05-08-2008 18:49:50
A friend wants me to change the fuel pump in his '98 Olds Bravada. I haven't been under one of these and I don't have the truck yet. Are there any unique issues with this vehicle, or is it a standard drop the tank and change it routine?.
Suggestions and opinions are appreciated.
Thanks,
Anthony
bradk
05-09-2008 06:36:11
 Re: O/T: '98 Bravada fuel pump in reply to MeAnthony, 05-08-2008 18:49:50
Remove the drive shaft to get it out of the way,fuel lines and filler/vent hoses are all at rear of tank.
There is a hose with a spring clamp at the front top of tank Be careful not to break it.Kinda sucky to remove/re-install.
If the quick coupler fuel lines are hard to remove,break the nipples off.The new pump is an entire assembly that comes with new ones.Easier to dig out the nipples when tank is removed.
Two elec connections on top at pump.New pump should come with new harness to splice in.
dave guest
05-08-2008 20:52:18
Maine Fordson, I like your thinking. Done that with a Ford van, but please don't weld over the tank. Metal screws are safer.
Bob
05-08-2008 19:32:46
Have the correct doohickey at hand to disconnect the quick-connects on the plastic fuel lines without damaging them. If there is any road dirt in them, spray them clean with some WD-40 or other favorite "loosen juice" to make the disconnection process possible.
Duner Wi
05-08-2008 20:04:14
 Re: O/T: '98 Bravada fuel pump in reply to Bob, 05-08-2008 19:32:46
Those plastic lines damage fairly easily and they are not real inexpensive.
Goose
05-08-2008 19:30:50
Why not go one step further and put a hinged door in the floor instead of welding right above the gas tank?
Maine Fordson
05-08-2008 19:02:13
I've had a '93 Bravada for the last 12 years, and have changed the fuel pump a couple of times in a quarter-million miles. I've always used the "find-all-the-gas-cans-you-own-and-drain-the-tank-then-drop-it-and-change-out-the-pump" method, but the last time I did it I swore that if I had to do it again I would just cut a hole in the cargo area to save about three hours' work. I figure that once you weld the piece back in and replace the carpet, nobody except you is going to know anyway. Of course, you know what your capabilities are, and there is no substitute for *your own* good judgement...
My 2¢ worth; your mileage may vary...
