Tractor Talk Discussion Forum
JD 70 change back wide to narrow front
tork rench
05-10-2008 15:38:21
Hello I saw a JD 70 with a schwarz wide front he has the original narrow is this going to be a nightmare to change back or not I only saw the tractor through email pictures,Thank you.
fixerupper
05-10-2008 15:54:14
 Re: JD 70 change back wide to narrow front in reply to tork rench, 05-10-2008 15:38:21
It's not too hard at all. I used to switch front ends on a 51 A twice a year. The toughest part will be wrestling them around.
The narrow front bolts up to the steering pedestal with four bolts and that's about it. If you don't have the bolts, get them before you start the project. The bolts that hold the steering arm to the pedestal now will be too short.
One bit of safety advice-do it on cement, lock both brakes and use stable jack stands to hold the tractor up. Jim
