Tractor Talk Discussion Forum
I need Belt dressing.
Devon
05-11-2008 14:56:41
I'm in search of belt dressing that doesnt come in a spray can for my grandpa's buzz rig. Does anybody know where I can get a tube or jar of it?
tatanka
05-12-2008 09:01:16
 Re: I need Belt dressing. in reply to Devon, 05-11-2008 14:56:41
I use a candle. Long one and rub the sides of the belt while turning. She quiet down quick. IF not you got a bearing noise somewhere. That how we found out the Alt bearing was going out.
Larry59
05-11-2008 20:32:07
I found over the years that some brake fluid applied by fingers does a good job. For this softens the rubber up some. Now do not pour brake fluid on it. Cause the brake fluid will east some paint of things. Use brake fluid on any rubber. We used it for squeaking of rubber mounds under cars. Works great and usually you have some around the shop.
NE IA
05-11-2008 20:06:19
Honey, tar, and a tube of tar in a calk gun is easy. I have not used belt dressing in probably thirty years. Belt dressing and parade tractors do not mix well.
Duner Wi
05-11-2008 18:28:28
I have used Pullmore belt dressing. Seems to work.
mEl
05-11-2008 17:32:42
I am 63 yrs old an watched my grandfather apply engine oil sparingly to flat belts to keep them from drying out and losing their grip. He was a owner of a farm equipment dealership and very knowledgable.
mEl
05-11-2008 17:18:56
The JD Workmen
05-11-2008 17:15:00
A regular bar of soap will work
gene bender
05-11-2008 16:48:48
In a pinch a little good old sourgum syrup will work seen it used as a kid.
Bob
05-11-2008 15:14:22
SUPPOSEDLY, "Shep's Stick Belt Dressing is still made by Sheps Manufacturing Co. Arthur,ILL. 61911.
"Glennview Tools" says they have it for $20.00 a stick.
Try emailing them:
glennview@ameritech.net
