Tractor Talk Discussion Forum
OT: TV Converter Box Coupon
El Toro
05-12-2008 13:46:57
I have an extra $40.00 coupon for a TV converter box if anyone is need of one. I put one of the tv's on cable and do not need this coupon and it will expire on June 13th. I bought my converter at Walmart for $ 49.97. It cost me $10.00 plus tax and it works fine. I don't get the channels out of PA with cable. Anyone interested send me an email and I will mail it to you. Hal
john *.?-!.* cub owner
05-13-2008 16:28:39
 Re: OT: TV Converter Box Coupon in reply to dangerdoc, 05-12-2008 13:46:57
El Toro said: (quoted from post at 09:26:44 05/13/08) It will only pick up the channels that are using digital. I can only get 2 or 3 channels. That will probably change by Feb 2009. I can receive more channels using rabbit ears. The converter I bought from Walmart is Magnavox. Set your tuner on Channel 3. It's easy to hookup. Hal
Practically all the stations are already broadcasting digital in addition to the current analog signals. If you are nto getting them you may need to redo your antenna system. The digital signals are UHF, and the long antenna arms will not be used anymore, only the short arms on the front. If you currently receive UHF stations you should be ok. I got an RCA converter, and the remote is dual function that will allow you to control the tv with the same unit.
El Toro
05-14-2008 10:06:08
 Re: OT: TV Converter Box Coupon in reply to john *.?-!.* cub owner, 05-13-2008 16:28:39
I have rabbit ears on the TV. How's all that flooding out your way doing now? I have cable throughout the house from the basement to the second floor, but no stations out of PA. I have an antenna in the attic, but I wired it to the first floor when I built the house. It would probably pickup more stations than the rabbit ears. I may be able to get to the antenna wire from the space above the garage. I may take
a look at that on Thurs. Hal
Mike M
05-13-2008 04:20:24
 Re: OT: TV Converter Box Coupon in reply to El Toro, 05-12-2008 13:46:57
I have my coupons , but have not picked up any boxes yet. Any certain ones any better than others ? and will it still work the old way if hooked up to the box now ?
El Toro
05-13-2008 07:26:44
 Re: OT: TV Converter Box Coupon in reply to Mike M, 05-13-2008 04:20:24
Dan-IA
05-12-2008 16:50:58
How long did it take to get one? I filed on 4/3, and haven't seen anything yet. Starting to get worried--except that I bought a HD tuner for $180 a couple years ago.
El Toro
05-13-2008 04:08:33
 Re: OT: TV Converter Box Coupon in reply to Dan-IA, 05-12-2008 16:50:58
I think I called them this past January and I received them in March. You will probably get them in July. You will then have 90 days to use them. Hal
El Toro
05-12-2008 15:20:06
The converter coupon has been spoken for. Hal
ShepFL
05-12-2008 17:03:06
 Re: OT: TV Converter Box Coupon in reply to El Toro, 05-12-2008 15:20:06
I ditto El Toro's offer. We have since gone to satillite TV and (internet - company paid) and I have 2 of the certificates. Free to who ever needs them.
email is open
ShepFL
05-13-2008 11:51:48
 Re: OT: TV Converter Box Coupon in reply to ShepFL, 05-12-2008 17:03:06
Coupons are spoken for and in the mail to WI.
Leroy
05-12-2008 19:08:27
How long did it take you to get them? Over 2 month ago sent for them and have not heard anything, Wonder if they ran out of them.
GA Dave
05-12-2008 19:49:22
 Re: OT: TV Converter Box Coupon in reply to Leroy, 05-12-2008 19:08:27
I ordered two by phone Saturday. The computer generated voice said it could take up to 12 weeks for delivery. Coupons are good for 90 days. Check your TV manual, ATSC tuners are digital and require no converter. NTSC tuners are analog and do need the converter. If on satellite or cable you don't need them either. David.
