Tractor Talk Discussion Forum
Irrigation pump
CBBC
05-12-2008 21:39:14
I"m looking at a Bauer Famos III 60 gear driven PTO irrigation pump. The guy sent me the specs and it says the suction is DN 65 and the discharge is DN 50.
What does the DN stand for???
Here is the link to the pump.
Any information would be appreciated. Thanks, Grant
Link
CBBC
05-13-2008 10:58:43
 Re: Irrigation pump in reply to CBBC, 05-12-2008 21:39:14
Thanks guys.
Yes I know electric is better. We run a 30 hp, a 50 hp and a 75 hp 3 ph 600 V vertical turbine pumps.
We are looking for a PTO pump which we can hook up and back feed into the filter.
Just back up if we loose power and need the pump for frost protection.
Thanks, Grant
buickanddeere
05-14-2008 05:44:14
 Re: Irrigation pump in reply to CBBC, 05-13-2008 10:58:43
Taht"s a serious amount of water. Where and what crops? Distribution system?
buickanddeere
05-13-2008 06:49:13
If you have the choice an electric drive is cheaper than purchasing diesel fuel. Add a variable frequency drive and flow/pressure can be dialed in without using inefficient throttle valves.
greygoat
05-13-2008 06:11:29
Thanks to "ISO", thats an interesting web site!
ISO
05-13-2008 05:23:15
Example
RAB
05-12-2008 22:42:12
More likely DIN? (Deutsch Industrial Norm). Meric 65 and 50 would be approx 2 1/2 and 2 inch. Just guessing.
Regards, RAB
CBBC
05-12-2008 22:56:46
 Re: Irrigation pump in reply to RAB, 05-12-2008 22:42:12
Hi RAB,
I thought about the metric - but 2 - 2.5 " seems pretty small for the picture of this pump. (I know, pictures can be decieving on the internet).
I thought the DN (not DIN) could be Deutches Numer or Decameter (10 cm) - but that would be dm. But none of that makes sense.
Any moer thoughts??
Thanks, Grant
Jerry/MT
05-12-2008 22:05:55
I don"t know what the DN stands for but my guess is that there must be some standards for the suction and discharge connect flanges on the pump and that"s what the DN numbers stand for. Ask the seller to explain it becuase to interface with this pump, you"ll have to mate up to these connect points.
CBBC
05-12-2008 22:13:39
 Re: Irrigation pump in reply to Jerry/MT, 05-12-2008 22:05:55
Thanks Jerry,
The pump is used and it comes with all the fittings etc. The guy we talked to is the shop / sales guy and was unsure - owner comes back next week.
My guess its a 4" suction and 3" discharge??
Just want to save myself an afternoon of driving to look at a tool which ends up being a toy.
Thanks, Grant
