Tractor Talk Discussion Forum
Kubota L245DT
fredwashere
05-14-2008 10:40:19
a Kubota L245DT with a loader what is the safe lifting capacity?
Rick Kr
05-14-2008 13:43:17
 Re: Kubota L245DT in reply to fredwashere, 05-14-2008 10:40:19
Fred,
Use to own one for 10 years. I built a big retaining wall with blocks that were around 80 lbs. 9-10 blocks is all it would handle SAFELY. Approximately 800lbs.
This was with a backblade. Heavy rear weights would help.
You could get a little more weight in, but you better make sure the ground is flat and creep along.
I put the tractor on three wheels one time with a load of dry limestone. That incident taught me.
Remember that tractor only weights around 1900-2000lbs.
Good luck.
Rick
Mike M
05-14-2008 10:59:24
Proper counter weight is the key. YOU MUST HAVE ALOT OF WEIGHT ON THE REAR. The loader relief valve will stop it from lifting too much for the loader. And of course if on a slope it will still flop over on you.
fredwashere
05-14-2008 11:30:08
 Re: Kubota L245DT in reply to Mike M, 05-14-2008 10:59:24
I haven't purchased the machine yet, can that machine hold up to lifting 800lbs 4'?
Mike M
05-14-2008 11:53:54
 Re: Kubota L245DT in reply to fredwashere, 05-14-2008 11:30:08
See if they have the owners manual on the loader it should have the ratings in it. If it is a Kubota loader I'd contact Kubota and they may be able to tell you. I once had a question on a Flail mower and got a response fairly quickly from them. go to www.kubota.com
