Tractor Talk Discussion Forum
Can you help me find this part
Arturo Balderra
05-15-2008 18:26:42
I was overhauling the hydramotor on a massey mf180 and as i pulled out the torsion bar the parts out of the bearing fell out on the floor. i found all but one therefore i am up a creek with no paddle. (what luck) so i need the bearing and the part number is #833795M1. i have called many places and they tell me that it is a discontinued part number. *note: it is a massey ferguson mf180 sn# cdw645004352 using a saginaw hydramotor. I will take used parts if thats all i can get. thanks in advance for any help on this matter.
greygoat
05-16-2008 05:43:23
 Re: Can you help me find this part in reply to Arturo Balderrama, 05-15-2008 18:26:42
The big professional bearing stores sell loose
bearing balls, though you might have to buy a
"package", and probably can't just get 1 ball.
Measure a ball very carefully with a micrometer.
Balls are available in inch and metric sizes
Arturo Balderrama
05-16-2008 07:57:32
 Re: Can you help me find this part in reply to greygoat, 05-16-2008 05:43:23
thanks, i will check. however it's not a ball it is a stick bearing very small. about an 1/8th inch long and 1mm in thickness.
Bendee
05-15-2008 23:00:27
And they go further than you would think.
Larry59
05-15-2008 20:24:30
 Use a Magnet to find in reply to Arturo Balderrama, 05-15-2008 18:26:42
Sorry I don't know the part you need. But do what I do.. got get a magnet to run the floor for that lost bearking. I have done this many times for screws are what ever when they fall. Look in all the places you think it could not have gone. That's where I find mine.. *S
