Tractor Talk Discussion Forum
Ford 2600-3600? Diff / Hyd fluid check and fill points
GunnyH
05-15-2008 18:57:08
I hope someone can point me in the right direction. I volunteered to help a neighbor out by changing the fluids and filter in his ford tractor. Everything was going smooth until I got to the differentials / Hyd in the rear axle. There are to large screw caps on the top right and left of the axle. I hope someone can tell me what goes where.
I would also like to know where I check the fluid level for the plug on the left? I did see one article the said that there was a dipstick near the PTO. This tractor does not have a dipstick there. I believe the fluid level for the plug on the right is checked by a square plug on the lower right side of the transmission.
There are no matching model numbers that I can find for this tractor. I have order to manuals online and neither show these plug or can even help me identify this tractor.
Napa did tell me that the replacement air filter I purchased would fit a 2600, 3600 4100, 4600 and a few others.
Any help would be greatly appreciated.
Rick Kr
05-15-2008 19:29:12
 Re: Ford 2600-3600? Diff / Hyd fluid check and fill points in reply to GunnyH, 05-15-2008 18:57:08
Gunny,
Don't have my books handy but I can tell you how my 1981 231 is. 231 is basically a LCG 2600.
Sitting on the tractor, with your feet on the running boards. There will be a plug 1/4"NPT if I remember, that is about the height of your ankle and just a little rearward.
Filler is right next to the rear of the seat mount, also on the right side of the tractor.
I don't believe there are dipsticks on the 2600/3600s, BUT there are a lot smarter people on here that can verify.
Hope this helps.
Rick
GunnyH
05-16-2008 12:56:00
 Re: Ford 2600-3600? Diff / Hyd fluid check and fill points in reply to Rick Kr, 05-15-2008 19:29:12
Rick,
Thanks for the help and quick response. Can you tell me if your tractor has to large fill plugs maybe 1 1/2" in diameter behind the seat and on top of the axle?
Thanks again for the help
