Tractor Talk Discussion Forum
Re: wd allis chalmers brakes
John (C-IL)
05-17-2008 10:30:26
Those pins will test your patience and religion! LOL You are headed the right direction. Solutions to your problem are many, but generally heat is involved. Some have had success by welding a flat bar to the pin and using it to rotate the pin to loosen it and then pry it out.
Others have cut the pin on the inside and then removed it piece by piece by knocking the outside piece into the housing.
