Tractor Talk Discussion Forum
Re: 540 rpm pto pumps
Roy Suomi
05-17-2008 17:35:11
Only a flowmeter test will show how efficient a pump is..They will tell gallons per minute at a specified pressure..Low readings will indicate worn pump or plugged suction screen in the reservoir..If no flowmeter is available , check for a suction screen problem....If no problem there disassenble the pump...Mark the 3 or more sections of the pump with a center punch so it will be assembled correctly..If it's not put together right, the rotation of the pump can be reversed...Worn areas where the gears come into contact with the center section will indicate worn bushings or bearings..There are specifications for pump wear..I think 8 to 10 thousandths wear is borderline worn out...If so , get another pump
