Tractor Talk Discussion Forum
OT! Drainage
genos
05-17-2008 18:07:29
I know you use perforated plastic drain tile around a footer to keep water out of basement, but do you also use perforated to drain the downspouts? they go to a seperate drain accrosed
the yard. thank you
jose bagge
05-18-2008 09:18:31
 Re: OT! Drainage in reply to genos, 05-17-2008 18:07:29
They make the same black plastic pipe without the perferations- I use it attached to my downspouts to duct water behind my hedges out of sight until I can empty it on the downhill grade away from the foundation of the house
Don L C
05-17-2008 18:27:39
No unless you have some special reason..... .Don
John S-B
05-17-2008 18:13:45
No, you want to get the water as far from the house as you can. And when you put in a new trench, if you have perf tile, it can flow back through the loose soil.
